2007 E60 530d LCI - DPF Not Regenerating
Old 11-16-2015, 01:52 AM
w.ashcroft's Avatar
My Ride: BMW E60 530d, 2007 LCI
Hello,
My DPF has now successfully regenerated, the key was resolving the 4030 fault which would not go away, more info about that here:
https://5series.net/forums/e60-discu...re-cat-143387/
Once this fault was resolved, I had no errors in DDE (even though my DPF was still heavily clogged, my makeshift piece of pipe with a hole in it was enough to fool the backpressure sensor and stop the 480A and 481A errors from returning).
As soon as I got on the motorway, regeneration went active and temperatures soared to over 600 degrees for several minutes. Once done, I removed my piece of pipe, reconnected the original and backpressure readings were now well below the limits.
Some notes:
  • I didn't notice any difference in engine noise, throttle response or smells whilst the regeneration was active.
  • The regeneration status changed to active even though the regeneration request status was not requested, I've only ever seen this say requested by DDE whilst there were faults preventing regeneration.
  • Forcing a regeneration put the regeneration active almost immediately, request status was still "not requested".
I hope this helps somebody somewhere, it's consumed far too many hours of my time and far too many unnecessary purchases (sensors etc...).
Old 11-16-2015, 12:05 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
I must say I couldn't tell my forced regens were underway except by the exhaust temp change - and maybe the fuel consumption.
Well done.
Old 11-20-2015, 09:52 AM
m0rt4l1ty's Avatar
My Ride: E60
guys pay attention to engine temperature....if temp lower than 75C (which is the case if your thermostatS are bad, quite common issue on diesel) auto regen wont kick in = clogged dpf
Old 12-29-2016, 01:22 AM
paneuro's Avatar
My Ride: 530D Touring M Sport manual
I have the same problem, a friend of my sons connected a machine to it and it said that there was a problem with exhaust back pressure sensor, I replaced the sensor but its still the same, the particle light comes on after about 4/5 miles, what is DDE? paneuro
Old 01-01-2017, 03:28 AM
bellabmw's Avatar
My Ride: 530D E60 LCI
After you fix thermostat etc run with a buddy open disv57 and keep deleting errors and activate regeneration one time.
I used to do this in mine with 3rd gear 3800 rpm and dpf was heavy clogged so it run sparks in end of exhaust in the road.
But i was tired from regenerations etc so I decided to remove it completely!
Old 01-01-2017, 04:10 AM
paneuro's Avatar
Whats wrong with my thermostat? also I don't have the facility to bring up errors or indeed clear them! anybody know what DDE stands for? Paneuro
Old 01-01-2017, 01:14 PM
bellabmw's Avatar
Somebody here wrote for thermostat if temps are lower than 75 then dpf will not regenerate.
DDE is ( Diesel digital electronics)
Old 01-15-2017, 08:16 AM
paneuro's Avatar
I have now replaced both thermostats as it was running at around 75 degrees, its now running at between 90 and 94 degrees but still no regeneration although I'm told I have get the codes cleared first. I would like to get a code reader of my own, any recommendations? I'm not to clever with computers but I will just have to learn. paneuro.
DavaiLave
08-02-2022 02:16 AM
Chet
152
07-08-2018 02:26 PM
vapuri
05-02-2015 06:09 PM
rackhacker9275
04-06-2015 04:55 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: 2007 E60 530d LCI - DPF Not Regenerating
