2007 550i Cooling Fan does not kick in
Old Apr 15, 2011 | 10:39 AM
BlackBear's Avatar
My Ride: 750i
Model Year: 2014
The car overheats in slow traffic because the cooling fan just does not engage.
I have a constant 12 volt reading on the plug going into the fan at all times. There is a little third wire that reads about 2 volts. When the car overheats that wire still reads 2 volts.
Is it correct to assume that the third wire is the control wire that should read 12 volts when the motor gets hot? Is it this wire that turns the motor on?
I have applied 12 volts to the plug and a positive 12 v to the little wire to turn the fan on, but the fan did not run.
Is there a relay somewhere? Is the relay built into the cooling fan assembly? This would require a new cooling fan for $700. Or is there a thermal switch somewhere I need to replace?
Thank you for your help.
dsummersm3
Nov 14, 2019 07:50 AM
Nickalitis
May 18, 2015 07:48 PM
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
audiophool
Apr 14, 2015 03:50 PM
XerXes310
Mar 26, 2015 01:10 PM
