2007 530i maintenance questions
Old Jan 1, 2023 | 03:04 AM
fast's Avatar
My Ride: White/Tan, Nav, comfort seats, sport steering wheels, sport suspension, active steering, rear window shades, rear shade, heated seats
Model Year: '07-530i
Default 2007 530i maintenance questions
The car in question has 70K miles and brakes and transmission fluid has never been changed.
The brake light sign lit up the other day "brake pads are at minimum" with no squealing or any pulsations on braking. Do I replace just the pads or rotors too? Shall i consider machining the rotors or just buy a new set?
Transmission :
Replace just the pan or shall I go all the way and get the mechatronic sleeve and seal and all that? Adaptations ?
Any good videos to DIY for the above and good store to order the parts?
Thanks
Old Jan 1, 2023 | 03:22 AM
donpb's Avatar
My Ride: '06 530i N52
Replace the pads. It's not recommended to machine rotors on BMWs. My e60 has 140k mi, I have not done the mechatronics, YMMV.
Old Jan 1, 2023 | 06:42 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Measure the rotor thickness. They have a minimum thickness beyond which you need to replace them.
Old Jan 2, 2023 | 08:55 AM
fast's Avatar
Have you changed the fluid at all, dropping and replacing the pan/fluid?
What's the minimum thickness and do I need to change the brake sensor too?
Old Jan 2, 2023 | 09:40 AM
twh's Avatar
twh
Engine: N52
2007 530i
Front brakes:
Rotor diameter: 324 mm
Minimum thickness (should be stamped somewhere on the brake disc): 28.4 mm
Rear brakes:
Rotor diameter: 320 mm
Minimum thickness (should be stamped somewhere on the brake disc): 18.4 mm
If you change pads, you need to change the brake pad sensor.
Old Jan 2, 2023 | 04:43 PM
donpb's Avatar
No.
Old Jan 11, 2023 | 11:19 AM
ZeroDfx's Avatar
My Ride: 2008 550i 6-spd; 2007 530i Sport
Transmission :
Thanks
With 70k miles, I doubt your rotors have been previously replaced, so I'd go ahead and install new rotors and pads, along with new sensors. You can buy complete rotor/pad/sensor packages from various BMW online suppliers like FCP Euro, Pelican Parts, Autohaus AZ, Parts Geek, etc. You can get pkgs. for either just the fronts or rears, or fronts and rears together. I'd be inclined to do the whole thing, front and rear.
Good luck.
Old Jan 26, 2023 | 04:16 PM
fast's Avatar
Changed the pads/sensor and not the rotors which felt smooth without any edges. The caliper brackets were bitch to install but was able to put them back on. Bought a Motive bleeder and be changing the fluid this weekend
Old Jan 26, 2023 | 04:32 PM
twh's Avatar
twh
Engine: N52
PSA on Motive Bleeder...the hose does not last forever. After a few years it burst one me while under pressure spraying brake fluid everywhere. Fortunately it was summer and the garden hose was near and I got the brake fluid hosed down before it could become paint stripper. I replaced the hose with some Teflon hose -- not as flexible, but not going to burst.
nazboy84
May 28, 2014 04:48 PM
ADD
Jul 24, 2012 12:20 PM
Original
May 19, 2012 09:39 AM
Opus
Apr 9, 2012 03:07 AM
joea9146
Mar 27, 2010 06:50 AM
