2006 e60 Amp Hookup
Old Jul 14, 2014 | 03:19 PM
UltimatePeter's Avatar
My Ride: 2006 530xi on Black 20's
Question 2006 e60 Amp Hookup
Hello Folks,
I am working on moving my 15-inch Kicker L7 over to my new e60.
I got a box that is the perfect width of the trunk with 3.85 cu/ft.
I have found a number of posts on this, but they are a little muddy.
Here is what I have come up with from reading others, but I want to make sure.
Here, we have the trunk factory sub amp harness:
From others' messages, it sounds as though the four black&stripe wires on the left are low level lines from the stereo.
0.75 SW/VI (Black and Violet) pin 13 AZBL- [Line level Left input -ve]
0.75 SW/RT (Black and Red) pin 3 AZBL+ [Line level Left input +ve]
0.75 SW/BR (Black and Brown) pin 4 AZBR- [Line level Right input -ve]
0.75 SW/WS (Black and White) pin 14 AZBR+ [Line level Right input +ve]
So I don't need a Line Output Converter, I can just splice in my RCA Wire Leads here, and run them to the aftermarket amp?
So, I am looking for some confirmation that this would be a decent route.
I was lead to this conclusion from Bruce on Post #2 here:
https://5series.net/forums/diy-do-yo...nstall-117775/
Thanks all!
(I will update some pics later after I finish)
Old Jul 14, 2014 | 03:26 PM
Boost7's Avatar
My Ride: E60
Model Year: 2005
contact Technic and buy his harness, that will make this project a plug and play thing. taking all the guess work out and also for you'll not have to cut or splice into your factory wiring.
https://5series.net/forums/private-m...ilt-loc-99857/
Old Jul 14, 2014 | 04:11 PM
Default Hmmm...
I guess the idea I liked about this was that we can hook right in to a low level, instead of amplifying this low level and then reducing it and then amplifying it again.
Otherwise, I would recommend this box to anyone with a 15-inch square sub and an e60.
It's a perfect fit:
Koqui79
May 24, 2015 06:47 PM
kane1111
Apr 10, 2015 04:40 PM
Adam1v
Apr 5, 2015 11:40 PM
BYS2
Mar 30, 2015 05:33 AM
ZeZe
Oct 15, 2003 12:58 PM
