2006 530 Low Coolant warning
My Ride: 2006 530xi
I just bought my 2006 530xi about 3000 miles ago and I don't drive the car much. It may sit all week without leaving the garage.
Recently after being driven ~90 miles and sitting on a sloped driveway all night, the Low Coolant warning appeared on the i-drive screen as I backed out of the driveway. I had had this happen on a previous E39 model and did not think much of it. I watched the screens, did a system check and everything else was okay. After the warning did not go off, I manually checked the coolant level and added less than 10 ounces of water, restarted the car, and the low coolant message was gone.
A month of no warning messages passed and I recently drive the car on 700 mile round-trip with no warnings, so I assumed the low coolant issue was a glitch. The car sat in the garage for a week without being driven and I went to back it out and the warning came on again. I immediately checked the coolant level and it required about the same amount as before.
I drove the car on a ~50 mile trip, let it set overnight, and manually checked the coolant level. It was fine.
There is no indication of any leaks on the floor and the car sits in the garage for days at a time, so it should be visable if that were the problem. There are no other signs to indicate a blown head gasket.
This is my first E60, as my other 5 Series cars have been E39s. Does anyone have any suggestions or things I should look for before I make a service appointment for an issue that they will not be able to recreate? I don't want to take it in if there is no need, but I also don't want to risk harming the engine.
Any feedback or additional signs to watch for would be greatly apprecaited. THANKS
My Ride: E90 M3
Model Year: 2011
Yes, had this in both my '04 and '08 cars. Simply top off the coolant in the expansion bottle under the hood. My dealer has done it for me as a courtesy because I am under warranty though some dealers won't do it.
My Ride: 2006 530xi
I might be a little paranoid since I just bought the car.
My Ride: 2008 535i:
1992 Camaro RS:
Originally Posted by Joesph530' post='986330' date='Aug 23 2009, 04:10 PM
So, I should not be overly allarmed that it has happened twice within 1000 miles? Even before this occured, I was considering having the coolant flushed the next time I take my car in for service. Hopefully, that service will confirm that nothing is seriously wrong.
I wouldn't be alarmed, but twice within 1k miles is a bit suspect. The last time around did you add plain water again or antifreeze?
My Ride: 2006 530xi
Hopefully, there will not be a next time, but I will use coolant if this occurs again before I get the car serviced.
My Ride: 2008 535i:
1992 Camaro RS:
Originally Posted by Joesph530' post='986363' date='Aug 23 2009, 04:43 PM
The first time, I was on the road and used bottled water as it was Sunday morning and all I had. The most recent time, I used plain water again because it was the weekend and I was not sure what is the proper coolant to use. I plan on having the car is due to have the brakes flushed as soon as I can get it in and I was going to have the service center top off the fluids with the recommended liquids.
I use Prestone 50/50 - you can get the pure stuff and mix it yourself for a little bit less $$$
My Ride: 2009 535xi, short shifter, no CDV
There could be minor leaking in the system. I do have exact same symptom in my previous e39 540i. The valley gasket in the middle of V-block is leaking. I did not know it until the leak goes worse and start drip from transmission case. Same idea could apply to e60 with I6. Not sure where is the weak point of this engine though.
The funny thing is that you only get this warning when engine is cold during morning, if you shot the engine down. Wait for 5 seconds then restart, the warning is gone. If you check the coolant later, it is in spec. I carry a bottle of coolant with me in trunk, stop engine immediately at morning when I got the warning. You will see the coolant is low at that moment, top of it. Used to do this few months once until within a month.... then I know I have to fix it.
After I replace the valley gasket, the problem is gone until I sold the car.
Simon.
Simon.
Skipped....
Skipped....
