2005 E60 Fault Codes
Old Sep 2, 2021 | 12:56 PM
  #21
swimrr's Avatar
My Ride: 2005 530i
Model Year: 2005
Engine: M54
A quick update on the resolution of this issue with my car. My mechanic spent many hours working on the car, including speaking with two very senior BMW technicians, and eventually found the issue in the passenger footwell wiring. He's a bit pissed at himself for not finding the issue quicker, but many of the modules were sending signals that contradicted each other. A very long story short, he ran new wiring and solved the issue. It sounds like nobody ever tries to repair these 2004-2005 elecrical K-CAN issues, with most throwing their hands in the air and replacing modules until nothing is left except for the wiring, and then replacing that as well.
I am so glad I have a reliable, trustworthy and honest mechanic who really knows his stuff!
Old Sep 2, 2021 | 08:13 PM
  #22
donpb's Avatar
My Ride: '06 530i N52
Thanks for the update.
Old Sep 5, 2021 | 07:40 AM
  #23
dv8ed's Avatar
Originally Posted by swimrr
Yeah, that's why I'm driving an hour away. He's also an indie, but seems to really know his stuff. Good news is, I took it for a longer drive yesterday and the battery is fully charged. I was wondering if the cluster was preventing sleep, but that also seems to be fine. The rear window lock indicator light went off after 2 mins and the shift lever indicator light after 15 mins.
One other thing I'm going to check is if the cluster is bad. Apparently if the KOMBI goes it can interfere with the K-CAN, etc, and you can test it by pulling the 7.5A cluster fuse. If the malfunction message goes away you've narrowed it down. Not sure how accurate this is, but thought it's worth a try.
Where is this indie mechanic located? Southern California?
Old Sep 5, 2021 | 02:17 PM
  #24
swimrr's Avatar
My Ride: 2005 530i
Model Year: 2005
Engine: M54
No, in BC, Canada. Your question has made me realize I need to update my profile!
Old Feb 1, 2024 | 01:11 PM
  #25
jasondomina's Avatar
My Ride: 2009 e60 528i xdrive 6 speed manual base metallic green on tan active autowerk tune Borla muffler bbs wheels Michelin tires tint and weathertec floor liners
Model Year: 2009
Engine: N52B30A
Default More info
I am dying over here with similar issues please be more specific about the cause and the fix
Old Feb 1, 2024 | 02:00 PM
  #26
swimrr's Avatar
My Ride: 2005 530i
Model Year: 2005
Engine: M54
From what I understood, there was faulty wiring in the passenger side foot well. This was causing the modules to malfunction and replacing the wiring solved the issue, but not after my mechanic spent hours trying to figure out why so many modules were reporting faults. Apparently on the earlier model E60's when one module malfunctions it sends inputs to all the other modules causing them to malfunction causing a constant feedback loop. Makes me think of string lights where one bulb going out causing the entire line to stop working. In my case it was the wiring, but if one module fails it could cause all the other modules to send faulty readings. I think they fixed this in the later model E60's so that one faulty module didn't cause haywire readings on all the others.
The testing of the modules is way outside my pay grade but hope that helps.
bamut
May 31, 2021 06:35 AM
luther99
May 9, 2013 04:59 AM
mullenc525
Apr 7, 2013 06:57 AM
Shydee
Feb 29, 2012 10:42 PM
monnot66
Nov 14, 2008 06:58 AM
