2005 E60 Fault Codes
A couple of days ago I went to start my 2005 E60 and got the "electronic system malfunction" message, along with the iDrive saying the wipers and cruise control were malfunctioning (easy to know as the wipers kept turning on).
I pulled 24 codes, 13 of which were K-CAN codes. I've checked the battery and alternator and both seem to be running fine, leading me to believe I have a faulty module. I'd greatly appreciate some guidance as to which modules to look at first and how to test those modules. Some reading has indicated the BCM/KGM could be a place to start, but I was hoping to get some more direction. I can post all the codes if helpful. Thanks in advance. |
Please do.
I need to check my settings as I didn't get notified of your reply.
The codes I pulled are: 907/present CAS: K-CAN communication fault D904/not present CAS: K-CAN line fault AOB1/not present CAS: Input. selector-lever position, inplausible E5C4/not present CID: K-CAN line fault E5C7/present CID: K-CAN Communication fault E2C4/not present CON: K-CAN line fault E2C7/not present CON: K-CAN communication fault D944/present DWA: K-CAN line fault D947/present DWA: K-CAN communication fault 9C54/present IHKA: AUC sensor E716/not present Message(consumer/load control, 0x3B3) faulty, receiver IHKA, transmitter DME-DDE E587/present KBM: K-CAN communication fault E584/not present KBM: K-CAN line fault E184/not present CD / M-ASK /CCC / RAD2 / CHAMP -GW: K-CAN line fault E187/notD present CD / M-ASK /CCC / RAD2 / CHAMP -GW: K-CAN communication fault 9D12/not present SINE: Internal Battery 27C3/not present DME: Thermal oil-level sensor CDA8/not present Message (status, instrument panel, 0x1B4) faulty, DEM receiver, instrument panel transmitter 5142/not present No message, receiver EGS, trasmitter KOMBI 5F49/present DSC: Interface, instrument cluster E484/present SMBF: K-CAN line fault 94F9/present SZL FAult, fanfare horn E244/not present SZM: K-CAN line fault E247/not present SZM: K-CAN communication fault Thank-you. |
Did you try and code or upgrade something. Your CAN BUS is having an issue. Recommend clearing codes and see which ones come back. You have a lot of not present ones. Do you have ISTA?
The MPM was replaced and coded in November by a shop, but I haven't had any issues since then. The new battery was also registered at the same time.
Today I had to move the car in the driveway so I could work on my van, and no messages from the iDrive. I'm going to clear all the codes and see what comes back. While it's nice not to have the problem, now I'm in the situation of knowing there is an issue but it not being present to diagnose. All I did was wash the car and remove all the leaves from under the wipers, including under the cabin air filters. Perhaps it was just mad at being so dirty. 😀 I don't have ISTA, but when I take my van in for an alignment on Friday I'll speak with the shop about next steps. |
Did you get anything wet under the hood while cleaning. This also could be a ground issue somewhere.
I don't think so, but maybe. It was mostly removal and wipe-up, then install. As soon as weather permits I'll go over it in more detail.
Thank-you for all the responses and ideas. I greatly appreciate it! |
Today I cleared all the codes and re-scanned. Got the following codes:
SMBF Seat Module Passenger E484/present SMBF: K-CAN line fault DWA anti-theft alarm system D944/present DWA: K-CAN line fault IKHA Integrated automatic heating/air conditioning 9C54/present IHKA: AUC sensor I haven't driven the car yet, but perhaps more codes will show. Not sure if this narrows it down or not, but good to see less codes. I'll check for more codes after my next drive. |
The AUC sensor means you just need to replace it. It's up to you if you want to.
I want to see if any other codes comes back on the CAN bus because the other 2 would indicate that there's an issue with those items. My DWA had the same fault and I just needed to switch out the battery that was in it. |
Today I took the car for another test drive, with the malfunction message coming and going, in addition to the brake, ABS and traction control lights on the dash also turning on and off. The iDrive control message "cruise control malfunction" kept coming and going. The speedo also dropped to zero a couple of times.
Got home and pulled the following codes: D907 CAS: K-CAN communication fault not present A0B1 CAS: Input, selector-lever position, implausible not present CDA8 Message (status, instrument panel, 0x1B4 ) faulty, DME receiver, instrument panel transmitter not present 27C3 DME: Thermal oil-level sensor not present 5142 No message, receiver EGS, transmitter KOMBI not present 5F49 DSC: Interface, instrument cluster present E484 SMBF: K-CAN line fault present E5C7 CID: K-CAN Communication fault not present E5C4 CID: K-CAN line fault not present E2C4 CON: K-CAN line fault not present D944 DWA: K-CAN line fault present A3B9 Message (Dynamic Stability Control, 0x1E9) faulty, receiver KOMBI, transmitter DSC not present A3A9 Message (steering column button signal , 0x1EE) faulty, receiver KOMBI, transmitter SZL present A3BD No message from the safety and gateway module, receiver instrument panel, transmitter Body Gateway Module/central gateway module not present A3B6 Message error (data storage Condition Based Service, 0x394), receiver instrument panel, transmitter CAS present A3B3 Message (active roll stabilisation, 0x0BE) faulty, receiver KOMBI, transmitter ARS not present E107 KOMBI: K-CAN communication fault not present E584 KBM: K-CAN Line fault not present E587 KBM: K-CAN communication fault not present 930C LM: Clearance light, left (E60, E65), outer (E60 Halogen), faulty present 9323 LM: Auxiliary direction indicator, left, faulty present E184 CD / M-ASK / CCC / RAD2 / CHAMP -GW: K-CAN line fault not present E187 CD / M-ASK / CCC / RAD2 / CHAMP -GW: K-CAN communication fault not present DA04 SHD: K-CAN line fault not present 9D12 SINE: Internal battery not presen |
| All times are GMT -8. The time now is 08:35 PM. |
