I recently discovered that Vacuum pump has a small oil leak. Looks like it's a common problem at my mileage (82k)
My mechanic cleaned it and said that it's not critical at all and I can drive with that (of course unless I want to spend money and pay for new vacuum pump + job=$700) Extended warranty refused to cover this (I was surprised by the way) What are your opinions, if I drive with this leak, can this affect car's performance in any way or get worth? Thank you |
Personally I am very paranoid about keeping things in a disfunctional state with my car. It eats away at me until I fix it and have peace of mind. I suggest you do the same and just get it done. Find a good indy mechanic and forget the stealership for this. Get the part from Garry at Newport BMW for the E60.net discount.
Basicly the pump is stupid easy to rebuild, if the parts were avaiable. I can't find them anywhere. But to have them made would be pretty easy. Its one o-ring in the housing that needs to be spec'd out to fit right. And the rotor is 3 pieces. All plastic. A rectangular rotor about 3x1.75x.5" that spins and 2 tips that slip in between the housing and the rectangle rotor. One would have to have new tips mad to replace the worn ones, and a new o-ring. That is pretty much it. Its a really simple device. I can get it for about $350 for a buddy at a dealer. But I would love to either get ahold of those pieces or make new ones. But most people here on the board are scared and would rather just get bent over.
I'd try and fix that eventually. jprovence has a point about rebuilding, but he is right too about most people not wanting to mess with all that.
Vlad, what was the extended warranty company's argument for not covering it? Wear item? Is it really? You do know that you can try to fight for it a bit, right? Either way, hope its gonna all work out for you, buddy. |
Originally Posted by v_therussian
(Post 1098933)
My pump was replaced @ ~80k under CPO for leaking. It is a critical component to the braking system (its sole purpose is to provide vacuum [aka:power] to the brake master, so that you have "power assisted" brakes). It is NOT a wear/tear item and should be covered by the warranty. |
(Post 1098933)
Vlad, what was the extended warranty company's argument for not covering it? Wear item? Is it really? You do know that you can try to fight for it a bit, right? Either way, hope its gonna all work out for you, buddy. And yes, warranty said: "Wear Item". I will try one more time, hope they change their mind. They probably wish they never sold me this warranty, because they are upside down already. They paid me more for my repairs then warranty worth. |
how do you put the pump back on ? How do you aline the flap with the cam shaft.
Originally Posted by derik
(Post 1244401)
I just got a multi-point inspection, and the dealer notified me that I need to replace my vacuum pump as well. Said it was not critical, as it was not leaking much, but said that if it starts leaking a lot it will become a problem (duh). Quoted around 800 I believe to get fixed *sigh*. Will have to get it done eventually.
Originally Posted by the5rivers
(Post 1245727)
fix it yourself for next to nothing. check out this thread and post 24 https://5series.net/forums/topic/912...n/page__st__15 |
