2005 545i no start after alternator swap
My Ride: Bmw 545i
Model Year: 2005
Had alternator changed and now no start.. I've been told 5 million things different by everyone. Anyone have info on INSA/d? Is it the program I need? Is there anything more simple or anyone who can help?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
If it was starting before then it's something that was done wrong. An alternator swap is just like any other car. What is it actually doing? Did you disconnect the battery before the swap?
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
If you got a new alternator, maybe the harness connector doesn't fit properly on your non OEM alternator?
May be the alternator is faulty at the B+ connection?
My Ride: Bmw 545i
Model Year: 2005
Yes battery was disconnected. It worked at first then it threw a code and went into "limp mode" battery checks out good but when swapped it runs okay for a bit then throws code again.
