2005 525i
idrive try’s to start up and then cuts of , then flashes bmw on lcd screen then goes blank again !!
I have this exact problem used to turn on on cold mornings and if I took the key out ignition then that was it away again but hasn’t came bak on atawl now replaced mpm module in boot because something was draining my battery so did That , got new battery and battery doesn’t drain now and lcd screen is still the same ??? Any help , thanks |
Yet another hassle with my car. This automobile has had more troubles than some thing I've ever owned!
About 1 out of each 10 begins my I-pressure screen is completely black. I haven't any radio, or I-force in any way. It seems to try to reboot while using because the display will flash grey then turn go into reverse. The most effective way to remedy the hassle is to stop the car for 5-10 mins for it to reset. Anybody else have this problem? My vehicle is ready out of warrantee so I have got to get this constant and pray that this is my final trouble earlier than the warrantee runs out! I'm so annoyed with this car... Tutuapp 9Apps |
| All times are GMT -8. The time now is 11:48 PM. |
