5Series.net - Forums
-   -   2004 E60 530i A/C not blowing (https://5series.net/forums/e60-discussion-2/2004-e60-530i-c-not-blowing-142661/)
tommyboy Jul 31, 2015 06:59 PM
2004 E60 530i 115,000 miles. The A/C no longer blows as hard as it use too. It will only blow about half strength.
Help please. Any ideas what could be the issue?
KyleB Aug 1, 2015 04:25 AM
half strength as in air flow, or temperature?
tommyboy Aug 1, 2015 03:56 PM
Half strength air flow. The little air that comes out is cold.
KyleB Aug 1, 2015 05:58 PM
When was the last time your cabin air filters were changed?
tommyboy Aug 3, 2015 11:19 AM
Cabin air filters were changed about 3 months ago.
jtbgonesailing Aug 3, 2015 01:18 PM
The idrive has a setting for air volume flow for air movement through the system. Don't rember exact description, but equal to low, medium, high setting.
tommyboy Aug 3, 2015 02:23 PM
The setting in iDrive system "Automatic program" is set to high.
No matter if put the A/C on Max, turn the dial all the way up, Auto mode, or any other combination. The blower still only blowers at half strength.
KyleB Aug 3, 2015 03:06 PM
You may have a failed blower motor regulator.
