2004 545i
According to the US E60 brochure the 545iA comes with all-season tires. No mention whether they are run flats.
The 545iA with the sport package and the 545i 6-speed come with high performance run-flats. All spares are space-saver.
I've read that all space-saver wheels with incorporate tire pressure monitors, but I can't seem to locate any mention about it in the brochure. I think it would be a must considering the fact that you would not be able to tell visibly whether pressure in your run-flat tire was low.
I can confirm that a tyre pressure monitor is included when you order the car with run-flats.
However the pressure monitor only alarms when the pressure is lost or very low. You still have to check the pressure regulary to make sure that you have the correct pressure. So it?s not like the 7-series RDC where you can read the exact pressure in PSI for each wheel on the info display.
Originally Posted by Skipper2' date='Jul 19 2003, 12:20 PM
According to the US brochure, all models will come with the pressure monitor for ALL tires. It will alert you if pressure changes by more then 30%.
Thanks...
kneemah
07-27-2015 02:06 PM
