2004 530i Hesitation
My Ride: 2004 530i
Hello everybody!
First of all, happy new year!
Sorry for this being my first post, but by reading online, I got confused. I have a problem, or I would say a dilemma.
I recently bought a 530i with 166000 miles on the odometer. I know that I have a M54 engine. I have to say driving a BMW is amazing. Anyway, I don't want to waste your time. Since I bought it, I have been having some issues with the acceleration. In fact, I am experiencing hesitation at low speed, acceleration speed (20-40 mph) and city driving. I took it to Autozone and their scanner is showing misfire in Cylinders 4, 5 and 6, System too lean bank 1 and 2, and System purge control valve circuit open (P0444) and also a vacuum leak. The gentleman over there told me that those are common issues in a Bimmer and I should ask for an online assistance to have more information about these issues.
I know that I need to replace the spark plugs, and I have read somewhere that I should use the NGK Laser Platinum BKR6EQUP instead of Bosch or Laser Iridium, because although being newer, the laser iridium is not fully compatible with the M54 engine.
Acknowledging that I have misfires, I am also replacing the Ignition coils (six of them). I have the choice between Bosch and Delphi. What would you recommend?
Those replacements I am about to do are fully self-deducted, and I have no experience in mechanic, whatsoever. I don't want any mechanic to scam me with low end parts, so I will be buying the parts and they will install them, so do you think anything else needs to be checked on?
Please, I am open to any suggestions, recommendations and advice.
Thanks a lot, I feel like this BMW will give me a new life
My Ride: 525i
Hi, and congratulations. I have a 2004 525i that I love. I am sorry you are having problems, but there are a lot of things that could cause your issues.
My first suggestion would be to get an OBDII reader, and then BMWhat app to see if your computer is suggesting there is an issue with the car somewhere. I know you said Autozone ran the codes .. but this app might show you better details. They mentioned "vacuum" and that's the very first thing that I would check out .. could be a very easy fix.
I hope that's helpful!
My Ride: 530i
Engine: M54
BKR6EQUP is the best plug to use in M54, you are correct.
With all those misfire codes, I'd definitely start with new plugs, see what that does for you. while you're doing plugs, do yourself a favor and replace the valve cover gasket set, I used to see cars that had so much oil in the spark plug wells that it was causing the coil to ground out and not fire the plug.
google 'm54 misfire' or 'm52 misfire' and youre going to see pages and pages of the typical M5X stuff; plugs, coils, valve cover gaskets leaking oil into the plug wells. I'd start with a fresh set of plugs and gasket set, see what that gets you.
Oh, and your evap system purge valve is shot. its not uncommon and easy to replace. there are videos on youtube on how to do it, its a 30 minute job tops and likely has nothing to do with your hesitation.
good luck.
good luck.
My Ride: 2004 530i
Thanks, I know, Bimmers make their owner happy lol.
I ordered the OBDII reader from BMWHat Germany, but I never received it. I will order one from their US store soon. I heard theirs is better than others.
I will let you know
My Ride: 2004 530i
good luck.
good luck.
Thank you for clearing my mind about those plugs. I am going to order them now from AutoHaus. But what about the coils? Do I really need to replace them? If yes, which brand would you recommend between Delphi and Bosch?
I will do as you suggest and replace the valve cover gasket too.
What is the name of the part I need to replace for the evap system purge valve? Sorry, I am a newbie, and I never did this before. What is its role?
Thanks again !
My Ride: 530i
Engine: M54
Hello Kyle,
Thanks again !
Thanks again !
start with plugs first. If you continue to get misfire codes on 4,5, or 6, take a coil from a known good cylinder (#2 for example) and swap it over to a cylinder that is giving you misfire codes. If your misfire code moves to cylinder #2, then you know you have a bad coil as the misfire code is travelling to whatever cylinder you're putting that coil on.
