5Series.net - Forums
-   -   2004 530d jack points using trolley jack (https://5series.net/forums/e60-discussion-2/2004-530d-jack-points-using-trolley-jack-105462/)
biggurs Oct 17, 2010 06:19 AM
I have run flat tyre package on my 2004 e60 which means I dont have a spare or a jack in my boot (trunk)
What I want to know is how do i jack up my car using my trolley jack because i dont have the bmw jack (i want to paint my calipers.... probably get stuck doing that too but thats only if i succeed in jacking the car up first!!!!!)
I have read somewhere on this forum about someone using wooden blocks cut to size so it fits into the jack points but is that really necessary?
There may be other jack points towards the centre of the undercarriage but I probably wont find them. Some people say they use the differential as a jack point and some definately say NOT to use the diff.
Its getting a bit confusing and to be perfectly honest I cant seem to be able to do anything without running into problems. Cant seem to be able to takeof the kidney grill which is supposed to be a piece of piss.
I want to paint the calipers but i dont want to use a trolley jack in the incorrect place and cause damage.
turboawd Oct 17, 2010 09:08 AM
1 Attachment(s)
there are four lifting points on the car with the plastic pucks, plus the center lift pad in the front.
you can see the two front lift points....jack stand, and jack
biggurs Oct 17, 2010 03:01 PM
brilliant!
thanks for that turboawd
I can just put my trolley jack onto the jack point and jack away??? dont need to put a block of wood to fit into the slot like the original bmw jack??
turboawd Oct 17, 2010 03:12 PM
Originally Posted by biggurs (Post 1256266)
brilliant!
when i jack from the front center pad, i remove the cup on my jack, cause i need the clearance and the cup would not sit on the pad right.
if you jack from the other 4 jacking points, either use a jack pad in the cup or place some shims, maybe heavy rubber pads inside the cup, so that the perimeter of the jacking cup doesnt come in contact with the car body.
jasperxli Oct 17, 2010 03:40 PM
Jacking from the diff may not be preffable but it's the only rear jacking point we have. Or at least from what I could see
biggurs Oct 18, 2010 12:57 AM
Cheers turbo and jasper, that's brilliant and thanks for quick responses. Beware I have somehow started a similar post which is just a duplicate of this one which I thought I didn't post successfully (done on my mobile) but it did so let's see if I can erase it or amend it somehow. Thanks again
nervno1 Oct 18, 2010 05:08 PM
i have jacked all my past bimmer at the center of the front subframe and rear diff in the back.
jasperxli Oct 18, 2010 08:37 PM
jacking from the diff is always safe as long as u know what your doing
