2004 525i no start
Old Sep 21, 2024 | 10:30 AM
Robdug750's Avatar
My Ride: 2004 bmw 525i
Default 2004 525i no start
I have a 2004 525i got it no start, cranks, has new fuel pump, 50 psi fuel pressure to rail, starts on starting fluid, getting low injector codes for all 6 cylinders. Could it be a faulty dme? Checked all fuses in the trunk and in the engine bay. Replaced fuel relay in the glove compartment. Any advice is appreciated
Old Sep 21, 2024 | 11:12 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Did you pull your DME to see if it was damaged?
Old Sep 21, 2024 | 03:21 PM
Robdug750's Avatar
like physical damage?
Old Sep 21, 2024 | 03:26 PM
donpb's Avatar
My Ride: '06 530i N52
Yes.
Old Sep 21, 2024 | 04:51 PM
Robdug750's Avatar
No physical damages on the board that I see, btw when the key is in the on position, should there be voltage to the injectors or only when cranking?
Old Sep 21, 2024 | 05:10 PM
I was asking more for water damage as these really don't go bad unless the cooling fan dies but definitely a possibility. Yes you're supposed to get voltage on acc
Old Sep 21, 2024 | 06:15 PM
Robdug750's Avatar
Cooling fan? Also I’m not getting ground or any voltage to the injectors when cranking it, checked for corrosion on the I think 5 plugs going to the dme, no signs of water damage that I know of.
Also I would like to add that when turning the key to the on position one of the errors is, ignition malfunction it still cranks it just tells me to have the brake pedal depressed, lastly on very rare occasions it will sputter couple times when you first try to crank it but die and just crank.
Old Sep 21, 2024 | 06:38 PM
If you have that error then that's why it's not cranking. Need to be looking at your transmission and the connector to the EGS. There's a cooling fan at the bottom of the DME area that keeps it cool. You'll have an error for that I believe. There will be no ground if you're having that error
Old Sep 21, 2024 | 06:59 PM
Robdug750's Avatar
It always cranks no matter what just doesn’t start, also what is the eggs and where is it located?
Old Sep 22, 2024 | 08:14 AM
I didn't mean cranking I meant starting. EGS is the transmission module
