Are 18" All-season Tires Available?
Old Aug 11, 2003 | 02:24 PM
Coops
Guest
Posts: n/a
Are 18" All-season Tires Available? If so, can they be run flat?
Also, does anyone know how SMG works? Is there a clutch? If not, is shifting by pressing the paddles only?
Old Aug 11, 2003 | 07:09 PM
555's Avatar
555
My Ride: E60
Not sure about the 18"s, but maybe this info will shed light on the SMG. I'm just not sure how current it is.
As far as I know, NO CLUTCH. Are the paddles even available in the US? I think it may just be shifting up and down on the shifter.
http://www.bmwworld.com/models/config/m3_smg.htm
Old Aug 11, 2003 | 08:02 PM
Somia25's Avatar
COOPS:
#1) I will reseach the tire question for you.
#2) The SMG that will be installed on the New 5 Series is the same system used on the Z4, not the M3 that the reply above this one directs you to. The systems are very different. I drove both of them at my local BMW dealer. Here is a link for the SMG used on the Z4:
SMG for the Z4
Old Aug 11, 2003 | 08:33 PM
Somia25's Avatar
ALSO:
Pic of SMG paddles on wheel and shifter in the new 5 Series !
And I would recommend that you read the great article LITSTER posted here:
Detailed E60 info
Old Aug 11, 2003 | 10:27 PM
Litster's Avatar
Since the article is kind of long, I pulled out the SMG section and start a new thread. Here is the link
http://e60.doit.wisc.edu/forums/index.php?...t=ST&f=2&t=112&
Old Aug 12, 2003 | 03:58 AM
Guest
Guest
Posts: n/a
Thanks so much for this great info.
Gizmo
Lounge
Jul 16, 2004 05:15 PM
coops
Sep 13, 2003 08:10 AM
coops
Sep 8, 2003 06:58 PM
coops
Sep 2, 2003 02:24 PM
Coops
Aug 6, 2003 05:15 PM
