166 wheel problem
Old 03-27-2009, 07:28 AM
steeda106's Avatar
My Ride: 2004 Blacked out 530i, Carbon Fiber Pillars, Carbon Fiber Emblems (Wheels, Steering Wheel and Hood/Trunk). Blacked out kidney Grill, Smoked side marker lights, 15mm Rear Spacers, K&N Filter, Window Tint, Navigon Syst. Breyton Front Lip. Bilistein Coil Over Suspension Front & Rear Droped 1.5" Genuine M5 Pedal set. Mtechnik side skirts, RPI Exhaust.
Is it safe to use a 15mm spacer in the rear of a 04 530i with 166 wheels? I had them with my stock wheels and dont know if i should take them off or leave them, and if i leave them will they harm anything?
Old 03-27-2009, 07:33 AM
Gene's Avatar
M5 offset? If so the 15mm spacers would push you to ET 13...think that might work...I am sure other members will chime in to confirm...
Old 03-27-2009, 07:37 AM
steeda106's Avatar
Yes i am looking to push the rear wheels out a little to give it that M5 look.
Old 03-27-2009, 09:16 AM
mhs525's Avatar
If they don't rub and the lug bolts are the right length I wouldn't expect problems...
Old 03-27-2009, 12:24 PM
Terraformer's Avatar
My Ride: 1985 325e (sold it in 1996) // 2001 Z3 2.5 / White / Blk Lthr / 5-spd (wife's) // 04 530i / Metallic Blk / Beige Lthr / 6-spd / Logic7 / 19" 166 Michelin Pilot Sp
M5 offset 166s, to make it look like M6 offset, requires 12mm spacers in the rear.
I wouldn't think that a mere 3mm would cause problems, but you never know...
Old 03-27-2009, 12:31 PM
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Yes, 15mm would work, that what i had when i had my 166.
Old 03-27-2009, 12:38 PM
DrLev99's Avatar
I think a 10mm in the rear is ideal on 166 M5 offsets. I wouldn't chance anything wider.
Old 03-31-2009, 01:13 AM
pdawg74's Avatar
ok n00b question.... Will stock lug bolts work with the spacer? Or are longer ones recommended?
Old 03-31-2009, 06:14 AM
Gene's Avatar
Go with Longer lug bolts...
Old 03-31-2009, 09:46 AM
longer bolts are necessary.
as for with 166s, with the M5 offset of ET28 in the rear a 12mm should do it to bring the offset to ET16, flushed with the rear fenders.
Quick Reply: 166 wheel problem
