15 mm spacers or not?
Old 07-22-2010 | 01:49 PM
Hashy's Avatar
Hi,
wondering if anyone can help. Ive just bought a 525d m spoert e60. Ive been offered some 19" wheels but the offset for the front is 35et. Ive been told that a set of 15mm spacers on the front two wheels only should be ok.
The question im asking is that if i install these spacers does it affect the quality of the drive (wheel vibration etc)?
All help is appreciated
Hashy
Old 07-22-2010 | 01:52 PM
melimel's Avatar
15 mm spacers arent going to affect your ride quality. Im just curious as to why you were recommended only having them on the front. Typically theyll only put them on the rear like i have.
Old 07-22-2010 | 01:55 PM
TakmaN's Avatar
My Ride: 2005 BMW 545i
Spacers will not affect ride or anything. Just make sure you clean the hub so the spacer sits perfectly flush and won't vibrate. +35 is a really high offset, personally I would go with a 20mm spacer to make it more flush (that is if the wheel is 8.5" wide).
Old 07-22-2010 | 02:02 PM
Hashy's Avatar
Hi,
The wheels which i am hoping to get come in the following sizes
front wheels are 8.5 x 19 et35
rear wheels are 9.5 x 19 et35
I looked on the following webiste and they advised that the rear off set on the rear should be around 35.
Do you guy recommend that i get a 20mm spacer for the front instead??
Thanks
Old 07-22-2010 | 02:03 PM
Hashy's Avatar
http://www.alloywheelsdirect.net/inf...ting_chart/bmw
Old 07-22-2010 | 07:19 PM
dentity's Avatar
My Ride: 2007 550i Titanium Grey Metallic - 6 Speed Manual, Sport Suspension, Premium, Cold Weather, Navigation, Shades, L7 Sound
Do you recall the change when you put them on? Did you have a better feel for the road, maneuvering and or cornering? i was thinking about it for my car but wasn't really convinced I needed it. what do you think...?
by the way nice to meet you and your whole crew down at the bear mountain meet earlier last month!
Old 07-23-2010 | 12:34 PM
melimel's Avatar
Nice to meet you too.. another rhode island friend. Sorry you got that ticket. That sucked.lol.
As far as my spacers and the ride quality nothing changed. Maybe it even got better cause the rear got a tiny bit wider and more aggressive.. but it just looks better
Old 07-24-2010 | 01:34 PM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
RSD spacers comes with free extended bolts
bestofthebest
03-28-2016 02:47 PM
HKninja
03-08-2016 09:50 AM
bestofthebest
10-02-2015 03:21 PM
keno75
09-24-2015 06:47 PM
hffvdbl
09-02-2015 01:58 PM
Quick Reply: 15 mm spacers or not?
