103,000 miles
Hello All, I have a 2004 530i and I have had it since March 2010. I purchased the vehicle from my local dealer with 85,000 miles on it. I know have 103,000 miles on my car because of all of the Highway driving I do.
Will my car be reliable within the next couple of years as the miles increase over time.???????????????
Only thing that i have done is oil changes and replace AC compressor.
Can someone comment?
Thanks
Thanks
Administrator
Congratulations, Fred!
I had my E39 until 197,000 miles. I'd still be driving it if a tree hadn't fallen on it.
I bought it at 92,000 and other than normal maintenance items, all I had issues with were radiator, alternator, pressure switch in passenger seat, and trunk lid latch. I SO wanted to get it to 200K. Damm!
Good luck - many of us have accumulated many miles on BMWs - but those mile don't come cheap!
Luigi is exactly right..
I have a 2004 530i as well. I have changed the expansion tank, waterpump, thermostat, starter, and oil pressure sensor all as preventative maintenance. Car runs flawlessly. Oh yea - had the tranny and diff fluid changed at 40K. The engines in our car (M54) is one of, if not BMW's best - these things are bulletproof.
And the M54 (I've owned 7 M54's) are not "bulletproof"...ignore a temperature issue and you'll warp your cylinder head with quickness! But i do stand by the M54 over any other engine i've yet to encounter. And that makes me feel good too.
I have 157,000 and its going strong with nothing but regular maintenance. I did replace all of the "lifetime" fluids recently (transmission, engine coolant and rear differential).
My Ride: E60
Engine: N54
E60Coyote.... you mentioned that you recently changed your 'lifetime' fluids. Did you do the transmission for the first time near 157k miles?
I only ask because I'm SO stuck in this catch 22.
I got my E60 with 55k miles, today it has 95k. I want this car to last me a very long time. Should I change the fluid now and buck conventional wisdom that says after 60k you just might introduce more problems with the transmission (ie: failure) than leaving it alone? (Damn damn I wish I would have just done the flush at 55k when I bought the car!)
I finally replaced my e39 after 246,000 miles.
I bought it used with 29,000 miles on it. (Who knows if that was "true" or if it had been rolled back, it was a shady place I bought it from) So I actually drove the car 217,000 miles.
I think over the life of my ownership I replaced the usual urethane bushings and suspension components, the center joint on the drive shaft, (with a reman shaft), a water pump or two, and a radiator/expansion tank. Not counting expendable parts like brakes, tires, etc. All in all it was a great car. Looking back on it, I wish I still had it, as this e60 535 has given me more headaches in two and half years than the e39 did over the life. Mainly HPFP issues, but still.
I kept up on the fluid changes and usual maintenance.
All without an extended warranty.
Find a good indy shop and you should be good.
chadillac2000
42
09-13-2017 11:15 AM
TexaZ3
05-06-2015 09:54 AM
