08, E61 steam from right rear corner of hood when stopped at a light
As mentioned in the way to long title. I’ve added coolant one time since I purchased the car in September of 22. Last week I noticed a slight smell of coolant and a little steam rising from the passenger corner of the hood. I got a low coolant message then. Now a week and maybe a half later a low coolant indication again. The expansion tank looks dry on the outside no residue, just dry dust like the rest of the area. I don’t have easy access to the bottom but there’s no fluid in the garage floor. Where should I be looking, I’ve heard the expansion tank is print to cracking and the steam seems to be coming from that area.
I found the leak. It’s on the passenger side low down on the engine in the area of the rear turbo charger. The water is leaking onto a hot pipe and evaporating. I tried to get a video but lighting just wasn’t right.
Sounds like the tank or hose. Most likely the tank. You usually need to get a mirror down there and bounce a light off of it to see.
farina43537 (05-13-2023)
The tank is forward and the leak is to the rear of the engine. I have a bore scope but it’s too hot right now to go down there. At least I know why I’m not seeing any puddles!
My Ride: 2008 bmw 535i sport
Take a flash light and look under and behind the coolant tank you will see coolant if this is the cause.
