08 550i p0120 please help!
I keep having an ongoing issue with this code. I put in a brand new battery, that didn't help. I put a new oem throttle body, that helped a little. I spliced a new connector on the throttle body harness that worked for 2 weeks or so now the code comes back and my car goes into limp mode. Is there something I'm missing? Please help! |
Originally Posted by ff54976
(Post 1595201)
is there a specific bmw code that points to the throttle pedal?
(Post 1595206)
isn’t the throttle position sensor on the side of the throttle body? That was the first thing I replaced |
(Post 1595236)
I replaced the pedal assembly two days ago and it didn’t help at all |
Looks like you need to get someone to read the codes with a BMW specific code reader. Somehow, now, I think that you might have an issue with the harness which you say you spliced and it worked for 2 days.
