Sponsored by:
Sponsored by:
Need Help!!!! 2006 BMW 530XI
Old 05-08-2018, 05:33 AM
Edwards095's Avatar
My Ride: Bmw 530xi
Default Need Help!!!! 2006 BMW 530XI
I have a 2006 BMW 530XI. The serpentine belt ripped and some pieces got stuck inside the engine. I took it out and I reset the timing. After doing so, the car would only crank and not start. So then I replaced both camshaft and crank sensors. Again, it cranks and no start. Then I checked the car if it is getting spark and it's not. I need help please!!!!!!
Old 05-16-2018, 11:51 AM
ukr
ukr's Avatar
My Ride: 530i n52
How many miles?
Hopefully somebody else can chime in about the timing. First thing to do is get the codes from the computer.
Old 05-16-2018, 12:03 PM
Edwards095's Avatar
My Ride: Bmw 530xi
Originally Posted by ukr
How many miles?
115,000 miles, the codes are
2A31- valvetronic eccentric shaft sensor
2CF9- throttle valve potentiometer 1
2A47- Valvetronic eccentric shaft sensor plausibility
2D09- Throttle
But these codes are because the car isn't running. I did a test and found out that the car is not getting spark and that's my problem right now. Any suggestions would be good.
Old 05-17-2018, 09:40 AM
ukr
ukr's Avatar
My Ride: 530i n52
It's possible the timing chain come loose messing up the timing...
Bimmer518
09-23-2015 06:33 PM
todg76
09-03-2013 08:06 AM
silverstar88
05-22-2009 09:54 AM
gvalenti
02-09-2009 10:31 AM
Quick Reply: Need Help!!!! 2006 BMW 530XI
