08 535i New Turbos and still getting 30FF
Old Oct 5, 2015 | 06:05 AM
derooster's Avatar
My Ride: 08 535i Titanium Silver Metallic, Sport Package, Premium Package, MTech front bumer
Default 08 535i New Turbos and still getting 30FF
Greetings
I recently got my turbos replaced in my 2008 535i under the BMW sib and I have still gotten the 30FF "Engine Malfunction, Reduced Power!" Code a few times. Got new turbos at 82k and I am now at 88k. The whole reason why I got new turbos was because of the 30FF Code... Why am I getting the code on brand new turbos?? Can someone help me out here?
Thanks
Old Oct 5, 2015 | 08:07 AM
Kaane's Avatar
Banned
My Ride: 535i
check vacuum system. If you are not getting full vacuum to the wastegates you will get the 30FF codes. They get very loose over time. I would go over all the rubber lines.
Old Oct 5, 2015 | 03:25 PM
illogic847's Avatar
My Ride: 2008 535xi
It could also be the camshaft vanos solenoids. They are cheap about 120 a piece and there is 2 of them. It is an easy DIY. Alternatively you can try cleaning them. Google to find the DIY.
Old Oct 6, 2015 | 04:51 PM
rorschach76's Avatar
My Ride: 535xit
Model Year: 08
Check the lines. I had my turbos and cats replaced under warranty. Vac lines were the last thing replaced to drop the code.
Old Oct 9, 2015 | 10:21 AM
ucsbwsr's Avatar
My Ride: E61 with all the mods
Engine: N54
Likely a boost leak since you have new turbos. After checking all the vacuum lines, tanks, and solenoids, move onto the turbo-ic charge pipe, intercooler, up-pipe, charge pipe, and charge pipe-throttle body connections.
Maybe have a friend stick their head in the engine bay while you rev it and see if they hear any unusual sounds (squeels, wooshes, etc.)
If you are mechanically inclined, pressure test the system.
Evan
derooster
Apr 24, 2015 10:08 PM
mishka69
Apr 18, 2015 06:15 AM
jl21
Mar 29, 2015 09:53 PM
JonathonK
Mar 27, 2015 08:13 AM
bmw545
Aug 8, 2004 12:47 PM
