08,528i rotors
My Ride: 2010 535i M sport
Model Year: 535i / 2010
Do I need to replace all 4 rotors and brake sensors when I replace the pads?
I am planing to do it before I get the brake light on.
Please advice.
Than you
Please advice.
Than you
My Ride: 2006 550i
You either need to resurface them or replace them; do not put fresh pads onto glazed rotors.
Make sure that you grease all of the guide pins and utilize a quality pad like Textar or BMW- avoid Duralast and Mintex like the plague, unless you like whistling brakes. You need to replace the sensors, period; DO NOT USE THE OLD ONES, unless you want to do the job over in a few thousand miles. They may not be broken from your pad wear yet, but they get dry and age over time. They're cheap- just buy them.
Here's a good DIY- if you're not an expert brake guy, I would recommend you get help- The E60 job is not for beginners.
http://www.bimmerfest.com/forums/sho...d.php?t=523439
Thank you.
A very detailed and complete guide that I was looking for a while.
Does any one recomend the following items?
R1 Concept Eline* Drilled & Slotted for Front and Rear w/ 1 Year Warranty
- Hawk HPS Pads Front and Rear
- Pair of Brake Sensors Front and Rear
$500.00
Please advice.
Thanks again
$500.00
Please advice.
Thanks again
My Ride: 2008 E60 528i
6MT, Sports Package, Premium Package, Navigation
Thank you.
$500.00
Please advice.
Thanks again
$500.00
Please advice.
Thanks again
PelicanParts.com
08-20-2015 01:25 PM
