'07 E60 maintenence & tail lamp/TPMS dash error help
My Ride: White/Tan, Nav, comfort seats, sport steering wheels, sport suspension, active steering, rear window shades, rear shade, heated seats
Model Year: '07-530i
Hello Folks,
Wife's car ('07 530i) is approaching 100,000 miles (all highway) and was wondering what maintenence (Coolant/transmission/ brake/belts etc) is recommended at this time?
Changed one of the tail lamps so how do I make the dash tail lamp sign go away?
Also has a tire sign on, which I did adjust the air pressure but it still stays on?
Any helpful video links be greatly appeciated.
Thanks
Thanks
At 100k, if you have not already done so, then you should change the coolant and transmission fluid. You also should change the spark plugs, air filter as well as serpentine belt and tensioner.
Did you change the correct bulb?
You have to reset the tire pressure warning. I think the reset is done in the Service Menu of iDrive.
Anyways, anything special with the ^ mentioned services that would need a dealer visit or my Indy should be able to do it?
Btw, what Transmission fluid do you guys recommend?
Thanks
socale39
09-05-2023 08:30 AM
DavaiLave
08-02-2022 02:16 AM
