5Series.net - Forums
-   -   06 530xi (https://5series.net/forums/e60-discussion-2/06-530xi-138758/)
crystalkjones Jul 6, 2014 06:03 AM
06 530xi
Something is always wrong with my car.got spark plugs changed..coil packs...mass air flow sensor..and its still missing when I come to s complete stop sometimes it may even cut off ughhhh
ROCKITMAN Jul 10, 2015 05:44 PM
Check the transfer case fluid. If it's super dirty, It may be the cause of the "miss".
pcy Jul 11, 2015 05:43 AM
IMHO, dirty transfercase fluid doesn't cause engine to shut off.
crystalkjones, you need to read diagnostic codes to identify the source [or point you in the right direction] of the problem.
Did these symptoms start after some work on the car?
ROCKITMAN Jul 11, 2015 09:56 AM
I had first hand experience with the same problem on a AWD X3. No codes, just a recurring loss of power during acceleration that resembled a "Miss" that was usually associated with a bad coil, spark plug, fuel filter or pump....etc. It is usually the most overlooked fluid change from what I have researched, because it is the hardest one to work on.
I am not sure about the stall, but it's possible that the car has more than one problem.
