06 525i fuel pump relay location
My Ride: 2006 525i
Model Year: 206
I recently replaced my fuel pump and fuel filter for my 2006 525i. Then I noticed 2 or 3 times the fuel pump error showed up in Idrive together with sluggish acceleration after a long drive.
Talked to a few mate and thinking the relay could be the culprit, i went buy a new reply from the dealer but upon opening the glovebox, NO RELAY is there whatsoever.
[IMG]
by https://www.flickr.com/photos/38252798@N04/, on Flickr[/IMG]
Any ideas where to look for this?
Thanks
[IMG]
Thanks
My Ride: 2006 525i
Model Year: 206
Used INPA read out the below (google translate)
6294 EKP motor: current too low
Error counter: 1
Mileage 120248 km
Voltage KL30 14.40
Volt Cooling capacity 78.00 l / h
Speed 60.00 km / h
Motor speed 1600.00 rpm
External temperature 36.00 ° C
Motor voltage EKP 9.50 Volt
Motor current EKP 2.40 Amp
Motor speed EKP 8949.00 1 / min
Implausible signal or value
Test conditions are met
Error does not exist at the moment, but already stored Error would cause a warning lamp to light up
Error counter: 1
Mileage 120248 km
Voltage KL30 14.40
Speed 60.00 km / h
