05 545i Oil Leak Drivers Side
My Ride: 645ci - 545i - CLK55 AMG
My 05 545i just leaked a pool of oil all over my garage and driveway. I think I found where its coming from but I cant figure out why. Pictured below is where I found oil spilling from when I turned the car on. Drivers side of the engine
![](http://img15.imageshack.us/img15/3775/xkhr.jpg)
Is that pic from under the car or top looking down? Where is the exact location? Looks like some sort of drain plug maybe?
That sir, is the dreaded alternator bracket leak.
- Disconnect the battery
- Jack up the car and remove the under-panels
- Unbolt the power steering pump and associated lines and hang it from a coat hanger off the sway bar.
- Remove the alternator
- Support the front of the engine
- Remove the drivers side engine support arm
- Remove the alternator bracket.
- Replace funny looking gasket under bracket.
