05 545i low oil grade question
I have a 05 545i with about 82k on it. This morning I started the car and let it run for about 10 minutes because it was cold outside. When I drove off I got an "engine oil at minimum level" I do not have any drip marks in my drive way and the car is running fine. I just got an oil change about 3-4k miles ago. Also after I stopped at the store this morning and restarted the car the warning went away.
Is this normal for me to have to add oil, between changes even if I am not noticing it leaking?
What grade should I use? I a have left over bottle from the last time I had the car serviced at local shop the guy used AMS 5-w 40. I am not sure that that guy knew what he was doing. Is that good oil and the correct grade?
Please recommend the best/correct oil for me to use
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
My Ride: 2005 545i SMG
If you live close by the dealership, just stop by at the parts department and grab a bottle of bmw oil. It only cost about $9.
Plus, may I ask why are you let your engine idle for 10 minutes? That would be actually bad for the car rather than help to warm up the car in cold environment.
Also, the reason you get the low oil warning disapear and appear again is because you are probably at the slightly above the trigger level.
Hope this helps.
Hope this helps.
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
When in doubt use the dipstick. if you're not sure what your mechanic used then just drain and fill. I use castrol 0w30 full synthetic, and it says it meets BMW LL01. I think Mobil 1 also have an approved oil. both about 7 per bottle, and you need 9 quarts.
My Ride: 2006, US Spec, 530i, Silver Gray, Black leather, Anthricite headliner, Steptronic, Navi Pro, PDC, Comfort Seats, Rear Heated Seats, Rear Shades, Folding Rear Seats, Bluetooth w/Blackberrt Torch, AUX Input, Bi-Xenon, AIB Angel Eyes w/matching fogs, summer wheels R118 w/PS2 tires, winter wheels R138 w/Michelin PA3 snows
Dipstick? I can't seem to find mine
Originally Posted by bobr2001' post='1046162' date='Nov 3 2009, 11:57 AM
Dipstick? I can't seem to find mine ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
socale39
09-05-2023 08:30 AM
