'04 545i coolant loss
My Ride: 545i
Engine: N62
In my case the leak was always when the system is pressurized and the coolant was hot. I let my car sit for a few days and never noticed a leak. Most of the coolant loss probably happens while driving or evaporates when hot.
Good luck OP! Keep us updated.
My Ride: E60 545i v8 6spd MT
99.9% sure I found where it is dripping. I finally got a glimpse of coolant running off of the block and onto the steering rack below the water pump. Still have to get under it and check to be sure.
Update!
I did the transfer pipe and valley pan gasket. Seems to have solved my issue. Only took about 5 hours with a collapsable pipe kit and an extra set of hands.
Now I have a whistling noise at operating temps coming from my expansion tank. So that will be next I guess haha
Update!
