04-545i; 6 M/T; No heat when cold?
I believe that the 545's are mechanical water pumps - mine certainly is. 2005 545 MT6.
My 05 530i M54, 1/05 production, the water pump is mechanical... Are you referring to the auxiliary water pump, by the heater valve, for rest heat and supplemental flow at idle, for the heater core?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Correction on my end. The pump itself is ran by a pulley but the water system has an electric self bleeding procedure.
The same procedure holds true for the 04-05 N62 in the 545i.
My Ride: 2004 545 6 M/T
So I finally had some time to replace the heater valve in my car and... I now have heat! I think anyway. It was a warm day (in the high 50's) so I can't tell if it is really fixed or if it is doing what it did before... I would get heat in warmer temps but no heat in colder temps (like 20's-40's). I'm gonna assume it is fixed but will let y'all know what it does in colder temps (here in Idaho... you know we ain't done with it yet!).
Also; my 545 (as do most) has has two water pumps... the main one which is mechanical, and the auxiliary, which is electric. I do not think my aux pump is bad though... I pulled codes on my car but did not find bad aux pump code; 9C77.
My Ride: 2007 BMW 550i
Update... not sure if I did this correctly but I I tested the electric aux water pump by removing the power connector to it and connecting 12 volts to the pump via a portable jump starter/battery pack. Nothing... no spark, no sound, no nothing. Does this mean my aux pump is dead? If so, any recommendations on where to buy one?
