'04 530 xenon upgrade
Old 08-06-2008, 11:37 AM
kekkos's Avatar
My Ride: 03 BMW E60 520i - Steptronic - Black Sapphire - Style 116 wheels (Pirelli PZero Rosso) - PDC - Beige Dakota Leather - Dark Poplar Wood
Originally Posted by Davey G' post='640324' date='Aug 6 2008, 12:13 AM
Hi Kekkos,
Cheers for that. I presume this is something I need to get done by the main dealer??
Can imagine they'll charge an arm and a leg!!!
Obviously the computer needs to be told that the car now has Adaptive feature.
Have you any idea if the Xenon should work on High beam also?
Ta
Davey
Hi Davey,
I don't have any idea. Upgrading my halogens to xenon is my next mod. There are a lot of members here that they have already upgraded to xenon and hopefully can answer the question for you.
Please keep as posted since there are a lot of people here that they want to do the same.
Old 08-07-2008, 01:28 AM
kekkos's Avatar
Davey,
If you don't care that much about the adaptive feature you can wire your xenon headlights using an aftermarket ballast and hid. This way you can avoid coding and any extra charges. Have a look here.
Old 08-10-2008, 09:44 AM
amd20's Avatar
Originally Posted by Davey G' post='640328' date='Aug 5 2008, 05:16 PM
Hi amd20,
If you solder a wire directly onto the spare pin on the Xenon highlamp unit and then straight to an earth. I stuck mine through the spare hole and then sealed it with silicone. I also added the capacitor to sort out error messages. Working great except still need to address the lack of Xenon high beam.
Good luck with the wiring.
Cheers
Davey
Hi Davey,
Thanks for the tip. Wiring is not my specialty. Can you provide some detailed instructions/pics to illustrate what needs to be done to the wiring? Which/where can I get the capacitor? So the wire that needs to be installed is just a ground wire that I can connect to any part of the car? I've been running everywhere and have been researching this upgrade forever and this part has got me in a big hole. I also checked with the dealer to find that a new set of wiring is $1200 each!! Thats the most rediculous thing I can imagine.
Thanks so much for your help.
Ahmad
umichchris
12-07-2015 03:33 PM
boozooface
07-28-2015 09:17 AM
SBrown712
07-12-2015 05:42 PM
cnwakobi
07-09-2015 09:46 AM
shervinj
07-02-2015 07:29 PM
Quick Reply: '04 530 xenon upgrade
