5Series.net - Forums
-   -   Which 02 sensor do I need? Code 2C39 (https://5series.net/forums/e60-discussion-2/02-sensor-do-i-need-code-2c39-146175/)
adampad Dec 11, 2016 07:57 AM
My 2010 535xi threw this code (2C39) and I'm not 100% sure which oxygen sensor I need to replace. RockAuto seems to have a bunch of options, any suggestions?
Thanks!
bellabmw Dec 11, 2016 02:16 PM
Reading some sources it says:
2C39 - DME: Oxygen sensor before catalytic converter
OBD Cloud - Pay As You Go Automotive Data. Powered by Autodata.
Can you reset all errors with INPA or some other software or by disconnecting battery then seeing again if same error comes.
