2 Attachment(s)
Have an opportunity to get a free set of these from a work colleague, but not sure if they will be a problem on my 2005 530?
I have seen that there would be both "no problem" and also that the hubs are a different size, and that the there might not be enough room for the brake calipers. He has two sets of tires, Blizzaks and summer tread. I'm hoping to be able to use them for winter. Any experience on whether these will work? Here are some pics: Attachment 127661 Attachment 127662 Thanks for your help! |
The center bore on these will be different if they came off a e39.
:l You will need hubcentric rings to make them fit properly. Although you can still use them without the rings... but it may shake a bit on the highway. |
I have e39 M5 wheels on my car and they fit fine, you just need to buy a set of hubcentric rings.
