E39 Discussion Anything and everything to do with the E39 (1997 - 2003) 5 series!
Transmission Fluid
Old Dec 15, 2019 | 03:44 PM
GroundRat's Avatar
My Ride: 2003 525i (American Spec, E39, 2.5L I-6, 4-DR Sedan)
Model Year: 2003
Engine: E39 (186K miles)
Default Transmission Fluid
Drivers,
Have a 2003 525i E39 with automatic trans (American specs, 186K miles). Transmission operates fine; vehicle shifts with no issues. Vehicle operates in Germany and drives at 120-140kph on autobahn (75-87 mph). I tend to enjoy the autobahn vs. race the autobahn.
Do I/Should I change the transmission fluid either with a complete system flush? Or should I do a filter change and replace the fluid until the system is at capacity? Previous owner did not keep maintenance records.
Been told by some local motorheads that due to the age of the vehicle, if it's not broke, don't fix it. On the other hand, I do like the vehicle and don't mind keeping until it dies.
Suggestions and advice welcomed. Thanks!
V/r,
GroundRat
Old Dec 15, 2019 | 03:50 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I would just do a filter and fluid change. I've always been told never do a flush on a trans just keep it fresh around every 50k
Old Feb 13, 2020 | 04:06 AM
Goz007's Avatar
My Ride: 530i e39 exc
Model Year: 2001
Engine: M54
100% change it(make sure u use the correct oil)check the color tag on the trans as this will indicate which oil goes in
Old Feb 13, 2020 | 09:59 AM
GroundRat's Avatar
Model Year: 2003
Thank you for the response. If you don't mind me asking, what would you say to the local mechanic who advises against the fluid / filter change? His reasoning is that a total fluid and filter change would remove some of the deposits that provide friction for the transmission to work. The removal of the deposits might cause the trans to shift erratically since new fluid doesn't have the sediment accumulated through years and years of use.
The trans is still operating fine at this point. Even when I use the "manual" option to shift the vehicle accelerates w/o a problem.
V/r,
GroundRat
Old Feb 13, 2020 | 01:42 PM
Goz007's Avatar
Model Year: 2001
Engine: M54
Well I'd be finding another mechanic that is confident on replacing it(u are best finding an automatic transmission specialist)not only is there a filter there are also magnets that will have accumulated debris on them, as long as u use the correct fluid for the transmission tag color, I'm sure u will have no issues, I've just changed the fluid&filter in my 2001 530i & the oil & filter was very dirty & the magnets were covered in metal, on the initial test drive I thought oh my the gearbox is no good, but after a few hours of driving it around the car has never driven(changed gears) so good....my car has traveled 300000kms
Old Feb 13, 2020 | 03:54 PM
A drain and fill is not a total fluid flush. You're only replacing around 6.5 liters. If you're wanting it to last do the drain and fill.
B20forlife
Mar 1, 2015 10:12 AM
TwoPedal
Oct 27, 2013 08:43 PM
vrmoreno3
Jun 12, 2011 09:29 AM
turboawd
13
Apr 22, 2009 12:06 PM
Krozi
Dec 22, 2008 06:33 AM
