Hi all, I just bout a 530i at an auction, car runs great, but the third brake light is not working. I tried changing the bulb and the fuse bu no luck, any suggestions?
Originally Posted by dcozzens
(Post 1342553)
I had the same problem, easy fix. Pop the bulb out and slightly bend the metal contact out inside the light bulb base so it makes better contact with the bulb. Chances are the bulb is not even burnt out. |
The third brake light is the LEDs on top of the rear windshield. I am not sure they just pop out THAT easily.
That's exactly what it was thanks
Originally Posted by jreyallen
(Post 1354032)
E39? Cause as Simon said we have LED's.
EDIT: This was in the E60 part of the board when I wrote this. Carry on. |
