5Series.net - Forums
-   E39 Discussion (https://5series.net/forums/e39-discussion-43/)
-   -   2001 525I crank,no start (https://5series.net/forums/e39-discussion-43/2001-525i-crank-no-start-152366/)
racerx2000 Mar 29, 2022 04:16 PM
Greetings! pulled into driveway, no problems. next day, crank, no start issue. 45 lbs fuel pressure @ rail. replaced both cam position sensors. no codes. Battery fully charged. crank sensor?? any ideas? thanks in advance.
donpb Mar 29, 2022 08:52 PM
Any one of those sensors being faulty would have thrown a code. What code reader are you using?
racerx2000 Mar 30, 2022 05:19 AM
Basic, cheap one.
donpb Mar 30, 2022 02:13 PM
Basic one will not show BMW codes, buy a BMW code reader, they have them for as low as $45. Its worth it to save you a whole lot of guesswork.
racerx2000 Mar 30, 2022 04:08 PM
will do. my first BMW suddenly a nightmare...thank you!
racerx2000 Mar 30, 2022 04:12 PM
Lots out there. Any recommendations?
donpb Mar 30, 2022 08:50 PM
Depends on how much you want to pay. I've owned a few different ones.
racerx2000 Mar 31, 2022 05:53 AM
I'm thinking $100.00 to $150.00?? It is a 21 year old car. I like it , but there is the age old question "What point do I cut my losses?" I would love to fix it if it makes sense. Thanks for your help!!
donpb Mar 31, 2022 11:54 AM
Buying a BMW code reader won't make you a mechanic. I'd suggest you go to a BMW specialist and have them tell you ALL that is going on, and then you can make a decision to throw in the towel or not.
racerx2000 Mar 31, 2022 12:00 PM
Well, Thanks for your help. Not worth the tow and the diagnostic. Just trying to learn something and I guess I did.
