1 Attachment(s)
My e34 535's fuel gauge is showing full when full and a quickly goes to 1/4 tank.(within a day or 60 miles). Any ideas if its the sender? the guage?
Most likely the fuel tank sender.
The gauges / instruments usually work from a voltage stabilised supply in the instrument panel and if the temperature gauge is OK, then the fuel gauge is OK. |
most likely the fuel sending unit it should be accessible through the trunk.
