Window control panels
Doing a little project, just wanted to see if anyone's had any experience with the window control panels on the pre-LCI cars. I need to remove and re-install them the easiest possible way. I've done some searching but came up dry. Are they held down with clips and I can just "pop" them, or is it more complicated and I need to remove the door trim?
Thanks guys!
Thanks guys!
My Ride: Estoril Blue 440i GC
Model Year: 2017
No easy way unfortunately.
The door panel has to come off (10 minutes) then the switch panel is screwed under the door trim.
Do a search for trim removal - I've done a write-up for the trim, including the door panels.
BMW TIS calls for a special tool, but a screwdriver and a Torx driver does the job.
Mike
Mike
ucsbwsr
26
Feb 26, 2025 08:22 AM
Germaniks
Aug 9, 2015 10:46 AM
PelicanParts.com
Jul 9, 2015 01:07 PM
