Who fix an Xenon Headlight Conversion from m-style?
Hello,
I want to know if somebody have already fix an Xenon Headlight Conversion from here:
http://www.mstyle-online.co.uk/E60-Lighting.htm
Is it easy to fix it? Does somebody have picture of the final reasult?
Thanks for all your reply.
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
I did it buy buying a kit which will have the same effect.
Below is a pic of the conversion halfway so you can see the difference between the halogen and Xenon (HID) bulbs on the standard reflector lenses, I have 6000k bulbs
The most expensive kit available is the the one I bought second hand - they are from www.HIDS4U.co.uk at ?199 new (now on offer), you need to loosen the headlight mounting to get it in - they do not give any iDrive error messages. You can get many cheaper versions which others on this forum have used without problems.
What you will not get is the projector lens with your proposed route - that is the proper way to go and I will eventually do this myself.
Good luck whicever way you go.
alfamaniacs
06-18-2015 03:55 PM
