What is needed to wire heated seats already have correct seats
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys about a year ago i fitted the sport comfort seats in my car the 20 way electric ones and i figured out these are also heated just today lol
the original seller didnt even know there were heated i managed to find out today as i was playing around with inpa seat module settings and decided to test seat heated
Wow all of a sudden seat started to heat up
now the main bit which bits will i need to make these function the proper way
i know i need the correct centre switch with the heated seat switches any idea if i need new wires if so which ones and what do they connnect to
do i have to rewire more wires back to the seats? as the seats already heat up if i command them from inpa?
before i fitted these i have fully electric memory seats
also do i have to add the correct SA code in to the Vo
is there one for Comfort seats at all?
thanks
thanks
thanks mike i wonder if i wil get any new function once i fully code the comfort seats as all functions already work..
apart from the heating
any one know of a working WDS link
also i seen two different type of center switch console
one with two plugs on the back
and one with three can any one check there mine is a 2003 pre lci thanks
i have seen two different versions of the centre console switches any one know which one i need both are pre lci
both have the same amount of buttons on the front but one has 1 extra socket on the back not sure which one i will need thanks
![](http://i.ebayimg.com/t/BMW-5-SERIES-E60-E61-HEATED-SEATS-PDC-DTC-SWITCH-PANEL-6985750-/00/s/OTAyWDEwMTA=/z/RmwAAMXQbjxRDUNn/$(KGrHqZ,!jgFDKvN0GfYBRDUNnGL4g~~60_12.JPG)
passtheword1
03-13-2015 03:17 AM
