5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   Volume Knob E60 (https://5series.net/forums/diy-do-yourself-14/volume-knob-e60-72140/)
arnirj Mar 6, 2009 09:09 AM
The volume knob does not work for the volume but I can mute the sterio with it. Is the promblem the volume knob or somthing else? Is it a big problem to replace it?
ENstig8or Mar 6, 2009 10:14 AM
If you mean it doesn't control the volume right after you start the car, then it's normal. It takes a little time for the Idrive to fully boot up and then the volume control knob will work. It's the same with the bluetooth connection. It takes a minute or so. Now if it doesn't work after the car has been running for a few minutes or so, then you might have a problem.
arnirj Mar 6, 2009 10:25 AM
I got the problem , It never works
Howitzer Mar 6, 2009 10:51 AM
Thank goodness for the steering wheel controls, right? =p
schulrog Mar 6, 2009 11:37 AM
HA i don't think i've ever used the actual volume button.
SmithsonGA Mar 6, 2009 02:44 PM
my 2008 5-r has a much better volume knob than my 2007. Can these be upgraded easily?
arnirj Mar 16, 2009 09:38 AM
I just talked to the dealership and they can?t get any spares for the volume knob so if I want it to work I have to get a new radio or some spares from a salvege car, this is the basic verson has anybody her been upgrading to tha satnav and have the spares for me? :D
billeul Mar 20, 2009 08:25 AM
If you are just looking for the knob, better try another dealer. My dealer ordered a replacement knob for me. Turned out the knob wasn't the problem and they ended up replacing the radio faceplate. All under warranty.
z06bigbird Mar 21, 2009 10:09 AM
I have gone for years without ever turning radio or music on in my vehicles. Like Bill Cosby used to say: "Turn the dang radio down; I can't read the street numbers."
timewa Mar 29, 2009 10:54 AM
I would open the unit and check the soldering of the rotary encoder. Use contact spray too. If that doesn't work, you can get the basic radio for very low prices on ebay (less than 100 euro on ebay.de).
Good luck
