Trim Removal
Old 03-15-2010 | 11:00 AM
jgulli's Avatar
Originally Posted by robg520d
I've just created a step by step guide of removing the dash and centre console trim from my e60, follow the below link to it:
https://5series.net/forums/topic/943...&#entry1115596
I'm gonna aim to get the guide together for changing the door trims sometime this week, just need to sort out the images...
have a bunch of pics from doing it too, let me know if you need any
Old 04-21-2010 | 11:22 AM
redEYEjedi's Avatar
Any update on this? the front and center console trims were easy to remove and wrap. I just need to tackle the doors. I know for the front doors the battery needs to be disconnected for my pre-LCI in order to remove the front side airbag, but is the process the same for the rear doors too?
Old 04-21-2010 | 12:15 PM
AlwynMike's Avatar
My Ride: Estoril Blue 440i GC
Model Year: 2017
Yes, the process is similar for both front and rear doors.
Have a look at https://5series.net/forums/topic/356...ard-door-trims - this should give you a heads-up on how to do it.
Mike
Old 04-22-2010 | 09:42 PM
louiemC's Avatar
My Ride: 2006 BMW 650i
I did removed my interior trim myself in my car.. check out the results in my threads.. i should of made a DIY but i forgot to take pics.. if you need help let me know! just send a pm and i can tell you what i know.
Old 05-11-2010 | 01:43 PM
robg520d's Avatar
My Ride: 2010(60) BMW 520d SE, Manual, In Sophisto Grey with Cream/Black Interior and Piano Black trim
Mike
You don't need to disconnect the battery, even if you have airbags, if you're careful enough removing the door trim, disconnect window control wires and door handle cables. Then get a friend to hold the door panel at max distance from the door, while you change the trim. This saves on alot of messing around in regards to disconnecting the battery
Old 05-19-2010 | 04:31 PM
ufans's Avatar
My window switch panels are scratched. Do I have to remove the door panel to replace?
Old 05-21-2010 | 05:24 AM
AlwynMike's Avatar
Model Year: 2017
Ufans,
Yes, unfortunately, you have to remove the door panel to get at the switches/panel
Mike
spykes
08-11-2015 05:38 AM
ucsbwsr
23
08-07-2015 08:08 AM
ucsbwsr
07-10-2015 01:54 PM
aarong15
E39 Discussion
07-09-2015 07:01 AM
jimmychef
07-07-2015 05:17 PM
Quick Reply: Trim Removal
