Sunroof seal replacement - any DIY?
Old 04-19-2009 | 01:44 AM
mikael's Avatar
Seems a bad sunroof seal is pretty common on the E60, leading to excessive wind noise in the cabin. Has anyone replaced the seal themselves? Easy? Difficult? Any pointers?
Old 04-19-2009 | 06:27 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I've never done it but it seems simple enough...
RA__Replacing_seal_for_glass_slide_tilt_sunroof_lid.pdf
Old 04-19-2009 | 08:26 AM
mikael's Avatar
You're a star Rudy, thanks!
Old 04-24-2009 | 08:23 AM
mikael's Avatar
Ordered the seal, should be here next week. Someone mentioned a procedure for adjusting the sunroof, anyone have access to that?
Old 04-24-2009 | 09:38 AM
Vegashipster's Avatar
I had my dealer do mine, the part was $47 from Advanced/Oriley/AutoZone. It took them about an hour.
Old 04-24-2009 | 11:12 AM
AKAlius's Avatar
How To Intitialize Sunroof
Old 04-24-2009 | 02:28 PM
Masterspy's Avatar
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
How much did you pay for the seal?
Old 04-24-2009 | 03:10 PM
mikael's Avatar
34.50 CHF (roughly 30 USD), at the dealer.
Old 04-29-2009 | 06:10 AM
bertolli's Avatar
My Ride: BMW E61, Nov-2005. M-steering wheel +sport seats. Panoramic roof, Lighting package, Xenon, Adaptive headlights, Prof. navigation, CD changer, Voice control, Bluetooth, Heated seats, 128 alloys -18 inch, B&W Tuning (hounslow)
Hi Rudy
Thanks for the PDF.
I'm planning to do the same for my E61. I have the feeling though that your instruction is for the standard roof?
If so would you know where I could find one for the panoramic sunroof on an E61 as I think it might be different.
Appreciate any help
Thanks!
Attachment 77180
Old 04-29-2009 | 06:35 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by bertolli' post='862699' date='Apr 29 2009, 09:10 AM
Hi Rudy
Thanks for the PDF.
Appreciate any help
Regards
Niek
You are correct that the E61's panoramic roof adds some complexity to the seal replacement process. Below are a few documents I created to help figure out the differences...
Seal replacement - main panel:
Master_RA__Replacing_seal_for_slide_tilt_sunroof_frame.pdf
Seal replacement - rear panel:
Master_RA__Replacing_seal_for_slide_tilt_sunroof_lid_at_rear.pdf
And for good measure, I created a document dedicated to the adjustment of the panel since there have been so many instatnces of wind noise with the panaroamic roof:
Master_RA__Adjusting_glass_slide_tilt_sunroof_lid.pdf
Keep in mind that the above adjustment document is integrated into the seal replacement - main panel document above...
