View Poll Results: Do you like how the rims turned out?
Voters: 61. You may not vote on this poll
Stock Rims Painted To Match The Paint.
#21
Originally Posted by Pmarszal' post='811729' date='Mar 9 2009, 02:23 PM
[update] Done with 3 wheels so far and will take photos of the car when finished [update]
Scheduled date for completion: Saturday March 14th, 2009!
#23
Originally Posted by Pmarszal' post='807425' date='Mar 4 2009, 02:05 PM
[3/4/2009][Update] Second Rim is finished. (2 days to dry) Will take photos of the car once I put the 2nd rim on it! [Update]
#24
Originally Posted by jdcinc21' post='823520' date='Mar 21 2009, 11:12 PM
+1
Sorry I havent included a DIY Yet! I been soooo busy with everything!
I promise to write one out this weekend!
#25
#26
![Wink](https://5series.net/forums/images/icons/icon12.gif)
OK! I am sorry it took me sooo long to get back to you guys with the tutorial!
Here it goes!
I am not responsible for anything whatsoever that goes wrong with the process. I am not a professional. Do at your own risk.
Supplies Needed:
4x - Big packs of 320-400 grit sand paper
4x - Duplicolor Rim Paint of your choice
2x - Duplicolor Clear Coat
1x - 1000 Grit Sand Paper
1x - Notecards (Flashcards) from Office Depot
Atleast 1x - Extra buddy to help!
DO NOT USE SANDING MACHINE!
Process:
Step 1 - Take off rims off the car.
Step 2 - Clean rims and make sure you get every piece of break dust off, if it gets a little too hard to clean, use a piece of the 320 - 400 grit sand paper to clean it off with water.
Step 3 - Sand down the paint, to a point your rim has no more paint on it! Mine actually was sanded down till the rim looked like plastic. (Not sure if all BMW rims look that way)
Step 4 - Start with back of the rim! Stick the flashcards between the wheel and rim. ALL AROUND!
Step 5 - Spraypaint from a distance evenly the back of the rim. Repeat process about 5 or 6 times, each time waiting for it to dry.
Step 6 - Flip Wheel over and place notecards again.
Step 7 - Spraypaint the front of the wheel. (6-7 times, each time letting it dry)
Step 8 - After spraypainting the rim 6-7 times and letting it dry, spray clear coat on front about 6-7 times as well.
Step 9 - Spray Clear Coat on back 6-7 times as well.
Step 10 - If your rims have some rough spots at the end, not to worry, use the 1000 grit paper lightly to get the rough spots out although I personally left it alone and the rims smoothed out over a period of 3 - 4 weeks.
Please message me with any questions and make sure you message me photos of how yours turned out!
Here it goes!
Supplies Needed:
Process:
#27
Here it goes!
Supplies Needed:
Process:
Here it goes!
Supplies Needed:
Process:
What is and where do you get duplicolor? price? I would like to paint my stock wheels alpine white.
#28
Originally Posted by Alpine White Girl' post='829563' date='Mar 29 2009, 12:01 AM
Thanks a lot.
You can buy it at Kragen and other Auto Stores. They run about 5-7 dollars a can!
Please let me know how yours turn out!
chadillac2000
42
09-13-2017 11:15 AM
TexaZ3
05-06-2015 09:54 AM
