steering knock fix
Originally Posted by dropped545' post='860135' date='Apr 27 2009, 08:01 AM
Hey has anyone here fixed the steering knock themselves,and does the wd-40 really work.if so plz explain your fix procedure... ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I didnt try that method, but i started having those problems and I actually replaced both my front control arms. that solved everything.
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
Btw, what happened to you guys? dissappeard from us. too bad you couldn't make it. Love how your cars looked. =)
Originally Posted by nigxdoof' post='860380' date='Apr 27 2009, 12:23 PM
What's up Curtis,
I didnt try that method, but i started having those problems and I actually replaced both my front control arms. that solved everything.![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
My Ride: 2005 530d
I also have the steering wheel knock sound, only ever noticable at low speeds over small bumps and when parking.
I notice it 9 times out of 10 when driving over a little raised lip of conrete into my drive way, really annoying
and would love an 'easy' fix fo it, car is out of warranty but has an aftermarket warranty.
My Ride: 2004 530i Grey
What's the fix with the WD40?
Originally Posted by Technik1' post='915594' date='Jun 18 2009, 09:07 AM
I have the same problem - steering knocks when going over small bumps or over raised concrete lips. I have had my 2004 530 since Nov/08 and it's always been like this. Overall, the ride seems bumpy and not comfortable.
Originally Posted by Dav530d' post='919649' date='Jun 22 2009, 01:26 AM
What kind of knock is this? Do you hear it in the car or out?
I believe is outside, I been noticing on mine as well and only does it when I make "U" turn or when im parked
![Getlost](https://5series.net/forums/images/smilies/imported/getlost.gif)
The knock is felt more than heard. You can feel the knock run up the steering wheel and into your hands.
