5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   Spring Install (https://5series.net/forums/diy-do-yourself-14/spring-install-72699/)
E60 545i SPORT Mar 13, 2009 01:42 PM
hey guys i just placed an order for some h&r sport springs with nerweezy and wanted to see if anyone has any suggestions or tips to make the install easier, noway am i going to pay for 3-5 hours of labor that i was quoted to do the job, ive done this on my e46 in the past multiple times and already know the rear should be very simple, the front on the other hand i heard can be tricky. i searched but didnt really find any DIY's here.
thanks
Jrowe Mar 14, 2009 03:49 AM
thanks
Just did mine today... And it's the opposite my friend... The Rear is the tricky part. All I can say is good luck this wasn't the easiest task at first...
E60 545i SPORT Mar 14, 2009 07:11 AM
Do you mind sharing what obstacles you came across?
Jrowe Mar 14, 2009 11:40 PM
Here my best advice.
http://www.bmwdiy.com/page/Installing-HR-L...0-3-Series.aspx
Follow all of those steps it basically almost exactly like doing the 3 series. Not sure about the rears because those were just a pain. But after seeing this site the fronts were a piece of cake.
hyethug015 Mar 31, 2009 11:32 PM
I should have a post on my experience somewhere dude. but like Jrowe said...good luck youll need it. front AND back is freakin hard dude. dont compare the LCI E60's to an E46.
PraiseTheLowered Apr 1, 2009 07:17 AM
you drive a complicated luxury sedan and you think a spring install should be easy? ha just pay the money and have it done right. if you mess it up its on you for thousands of dollars but a shop will warranty their work
