sport suspension question need advice
Old 09-23-2011, 10:00 AM
jtjr0313's Avatar
i want to put in new springs and just needed to know if there is any trick or something that i should know that will make this easier or if there are any warnings out there on changing springs that i need to know about before i break something. thx
Old 09-25-2011, 12:03 PM
AchtungE60's Avatar
My Ride: E60 530i
Same process as every other spring. Since you're tackling this job, I would assume you've done it before. Just look into the BMW procedure before you do it in case there are "special" things they recommend. The front end is going to be tedious where the thrust arm and wheel carrier join.
Old 09-25-2011, 03:50 PM
jtjr0313's Avatar
where can i get this bmw procedure??? and yea id rather do it then pay somebody a whole lot of money for something i can do myself...
Old 09-26-2011, 10:28 AM
epilithic's Avatar
My Ride: 2008 535i
If you dont weigh more than 200 pounds i would recommend having a friend near by. I had to put all of my body weight + a friends weight on the strut/rotor assembly in order to get the top of the strut to clear the fenders. I also had the spring compressors on so that will give you a good idea of how much force you need.
Old 09-26-2011, 11:23 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Take a look if you can find any help or tips here:
http://tis.spaghetticoder.org/e60/53..._axle/General/
- Antti -
Old 09-29-2011, 10:26 AM
epilithic's Avatar
My Ride: 2008 535i
This proved to be really useful when i replaced my struts/shocks
https://5series.net/forums/topic/853...hocks-install/
Old 10-01-2011, 11:13 AM
Canuck545's Avatar
My Ride: 2004 545i 6 speed
very helpful links. Refreshing the suspension is always money well spent.
Old 10-02-2011, 02:00 PM
AchtungE60's Avatar
My Ride: E60 530i
Give me the last 7 digits of your VIN and I'll see if there are any special procedures for you. Also send me a PM when you reply because i'm not here everyday.
Old 05-14-2012, 06:16 AM
stecom90's Avatar
Hello,
A friend with E61 2005 want to retrofit "$226 SPORTS SUSPENSION SETTINGS".
For the rear, I just need coding in EHC ecu, with ncs, a new ride-level ?
Old 05-20-2012, 07:24 PM
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by stecom90
Hello,
Does your friends car have air springs or something?
Quick Reply: sport suspension question need advice
