SOS button = Speed Of Sound
My Ride: 2004 e60 m54b25
it was actually easier than i thot it was going to be. For those of you who have nothing better to do with your time than f*** up some wiring, i have successfully re-assigned my eject-o cover light up SOS button to act as my "e60 sport mode unlock" button.
DIY:
Use your man hands to grip the SOS button and pull it down/out and unplug it.
Should be a 4 pin white plug. the 2 outside wires are power and ground for the illumination/dimmer.
the 2 inside wires are where you want to put your 2 pins you created for your DIY sport mode button.
take a needle and un-pin the 2 inside wires of the SOS 4-pin white plug.
Run the 2 wires from your current sport button setup through the dash and up the A-pillar and plug them into the 2 inside terminals of the white plug.
Plug it back in to the SOS button and press the SOS button away back into its nest.
(2 wires from terminal 2 and 3 of white SOS plug to back of DSC button pretty much)
BAM. works like a charm.
just tape up the 2 original SOS wires u took out so they don't touch.
Do I need to state the obvious.... Your SOS button will no longer be able to send out an SOS. and you can remove your old inferior sport mode button.
DIY:
![Cool](https://5series.net/forums/images/icons/icon6.gif)
So far 2140 km and no SOS call error message. Lol I don't have a scan tool any more so idk if there's any hidden faults, but @ 200k miles on the kombi im not in a hurry to go get it plugged in just out of curiosity. Now I need to figure out something to cover the big ugly hole I cut in my center console where I had my old sport button half-ass'd into place before I had this brilliant solution
