22 Attachment(s)
Hi all,
I just replaced my old chrome trims with ditto black ones - Shadow Line: It's quite easy. The only thing is that you have to be careful about is not to scratch neither the new trims nor the paint / existing trims. OK, first of all I started with the left front door. Remove the rubber seal. Attachment 21486 Here we go, gently hammer the trim step by step. Check were the clips are and hit it right there. Attachment 21481 I wrongly began removing it at the end of the door frame. If you do as I did, the end of the trim has to be bent out! You should begin at the mirror and work your way out until the end! Attachment 21482 Attachment 21483 Attachment 21484 I made some safety precursions as I didn't want the trim to fall down and scratch the paint! Attachment 21485 The trim is only mounted with clips. Nothing else, exept the seal, has to be removed. Here we go, first one removed. Attachment 21488 After that the upper trim has been removed, continue with the lower one. Use the hammer and hit it at the end and the trim will loosen. When you have enough room just grab it by your hands and pull it gently upwards. Attachment 21489 Attachment 21502 Be careful so that the end of the trim doesen't press against the paint! I put some extra layers of tape for protection. Attachment 21491 Use the same procedure as for the front ones. Begin with the lower one as it blocks the upper trim! Attachment 21490 Attachment 21492 Attachment 21493 Removed rear upper trim. Attachment 21494 Now it's time to mount the new Shadow Line trims. Simply press the upper ones with your bare hands onto the door frame, front and rear. Remember to mount the upper rear door trim first as the lower one blocks it! Attachment 21496 For the lower trims you need to use a wooden piece wrapped in a cloth so we doesn't damage the new trims. Begin in one end (for the front door you have to insert it a bit under the rubber seal that surrounds the mirror frame). Hammer it down carefully until it hits the bottom. Remember to close the doors as this gives the necesarry support when hammering. Attachment 21497 The seal has to be somewhat adjusted, use as small screewdriver and carefully flip it out. Attachment 21500 Finished!! Attachment 21498 Attachment 21499 Attachment 21501 Ciao and good luck with your conversion! //R |
great job...thanks for the DIY write up :)
Great diy and manual mate!!!! But the hard thing you did not change; the trim in the middle. I?m concidering changing to shadow "hochglanz" so the middle trim you left (because it is already normal shadow :) )must also be changed.
I understood that there were some screws...but a pictured manual like your?s would be great. |
I understood that there were some screws...but a pictured manual like your?s would be great. Thanks. I no nothing about any screews. The "Hochglanz" is a bit more work I presume. All the vertical tirms and the mirror frames has to be replaced. //R |
superb job :thumbsup: :cool: and looks great too!
Originally Posted by Robbo' post='308344' date='Jul 8 2006, 01:55 PM
Thanks.
Originally Posted by bmw4life' post='309344' date='Jul 11 2006, 10:04 AM
Hey, why did you do that, I opt out for sports package cause i wanted the chrome? is that just ME???
//R |
great job :thumbsup:
Great step-by-step!
What are the part numbers and how much do they cost?
